Squeaky clutch
Squeaky clutch
So basically the clutch pedal/unit in the cab squeaks when the clutch pedal is depressed and I wasn't able to fix it by spraying WD-40 on the pivot so I'm at a loss and it seems to act up as it gets warmer if that helps, any ideas?
Only from above may they judge my actions below.
Thomas
Thomas
Simply remove the clutch slave, grease the ends of the rod between the clutch slave and the clutch fork, and that should fix the problem.... `If that's what it is!
http://www.ozpinz.com
