Another Carb question
I was working on the Pinz trying to set the timing and carbs. I know there has been alot of talk about the spindles on the butterfly of the carbs needing to be re-bushed. I took the linkages off of the carbs and wiggled the spindle where the linkages attach and there was some play in both of them, not much but there was definitely some movement. Adjusting the timing doesn't seem to help my 'missing' problem. I would think that there should be no play. Should they be rebushed?
- McCall Pinz
