It is about 0 degrees or below in Denver and my idle is messed up. Throttle is sticking a bit as well. Hope someone can help.
Starts and idles fine, after driving, when decellerating to a light my idle drops to stalling point and then comes back up after about 5 secoends or so (if it didnt already stall). Also when getting up to RPM to shift it will rev a bit between shifts.
None of the above happens on a normal day only seems to be when it is very cold. Any suggestions wll help!
Very cold in Denver and I need my idle is ?
rekogniz11
- McCall Pinz
- McCall Pinz
