Very cold in Denver and I need my idle is ?
rekogniz11
Post by rekogniz11 »
It is about 0 degrees or below in Denver and my idle is messed up. Throttle is sticking a bit as well. Hope someone can help.
Starts and idles fine, after driving, when decellerating to a light my idle drops to stalling point and then comes back up after about 5 secoends or so (if it didnt already stall). Also when getting up to RPM to shift it will rev a bit between shifts.
None of the above happens on a normal day only seems to be when it is very cold. Any suggestions wll help!
McCall Pinz
Post by McCall Pinz »
Make sure the flap on the air intake is set so it moves and sucks pre-heated air into the carbs at idle. Also, when its below about 20 degrees, I'll block off the grille with some cardboard to get the engine a bit warmer
ka
Post by ka »
mcall - do you leave the tunnel blocked like that while driving?
1973 710m
McCall Pinz
yes I leave it blocked off while its really cold. It doesn't seem to hurt anything.
