Transmission Input shaft
Trying to get my parts ordered. I have to change out the input shaft on the transmission due to a grove that has warn in it. Noticed it when i pulled the clutch. When changing this shaft what other parts (gaskets, seals ect) do i need? Thank ahead...... Shawn
74 710 RAGTOP
Jeeps 74,86,92
max iv 6x6
Excursion
Ford f350 D
Jeeps 74,86,92
max iv 6x6
Excursion
Ford f350 D
Re: Transmission Input shaft
you might be able to use a repair sleeve if proper size is avalible.
http://www.vsm.skf.com/en-US/HeavyDuty/ ... leeve.aspx
Ed
Ed
pinzdriver
You will have to split the trany case to replace the input shaft and take it from me you dont want to open up that can of worms.
- PICT0010.JPG (73.81 KiB) Viewed 3858 times
tony in az 73 pinz 6X6
pinzdoctor is the name,pinz repair is the game!
- cruzoropeza
been there take it a step at a time! your lucky you know where the problem is, one of my transfer gave out in my pinz and i could pin point where the problem was i ended up taking it all apart to find the problem!
- at this point a started getting worried if i was going t be able to remember how to put it all back together!
- IMG_1033.jpg (86.49 KiB) Viewed 3851 times
- IMG_1040.jpg (84.18 KiB) Viewed 3851 times
Man that looks like a project from .....!cruzoropeza wrote:been there take it a step at a time! your lucky you know where the problem is, one of my transfer gave out in my pinz and i could pin point where the problem was i ended up taking it all apart to find the problem!
74 710 RAGTOP
Jeeps 74,86,92
max iv 6x6
Excursion
Ford f350 D
Jeeps 74,86,92
max iv 6x6
Excursion
Ford f350 D
rospaw I sent you a PM check your messages
