I'm installing my guages and can't find a good location for the oil temp sender. An older post suggested in the thermostat housing, but the probe is too big.
Suggestions?
thanks,
Michael
Where to install oil temp sender?
michaelh712
michaelh712
Re: Where to install oil temp sender?
OK, Solved!
I pulled the thermostat/oil cooler and found a "bung" (thick casting) just below the port for the oil pressure sender light. Man, that thermostat is MASSIVE! I was barely able to fit the oil temp sender into the hole I drilled and tapped, and the guage is working great. Needed some help from my friend JB WELD to make a flat surface (amazing stuff, wouldn
t leave home without it). Now, to set some baseline temps and pressure readings.
