24v 4 channel amplifier project finally "Complete"
McCall Pinz
Re: 24v 4 channel amplifier project finally "Complete"
Post by McCall Pinz »
audiocontr wrote:The amp has 4 diodes. One on each channel on the input path. You want to cut the trace of each one. It will increase power output. They are designed to protect the amp from high voltage input signals. Something that an iPod will never cause. I simply never installed mine. Yours come pre installed
OK, I think I understand that and I'll look for more info before doing anything on the amp. Still can't find the camera... Dang kids!
eat, sleep, Pinzgauer
McCall Pinz
Here are some quick pictures. The more detailed ones will follow when I pull it apart to install the subwoofer.
the amp and crossovers are hidden in a space below the snorkel.
McCall Pinz wrote:Here are some quick pictures. The more detailed ones will follow when I pull it apart to install the subwoofer.
Nice job!
waterdog
Paraguay
Post by waterdog »
below the snorkel???? that means they are waterproof!!!???? :mrgreen:
1985 710MS
1985 712MK
McCall Pinz
waterdog wrote:below the snorkel???? that means they are waterproof!!!???? :mrgreen:
yeah, the irony of the whole thing became apparent while working on this. :oops: oh well, water never gets into the back... right? :roll:
lol. I like the box! I'll have to build one as well!
Post by stiffler4444 »
What a great enclosure! Prepare to be copied copiously I'm sure!
Heed
Post by Heed »
Nice job!
I like the judicious use (recycling?) of the 'non-Cuban' cigar box!!
Sigh...up here in Canada I can't have automatic weapons....but at least I have unrestricted access to some mighty fine cigars!! :wink:
Bob
1990 - Mercedes G-Wagon 250GD
__________________________________________
A goal without a plan is just a wish!
McCall Pinz
Meant in the best possible way, and to quote a Monty Python movie- "You luckyy, luckyy baastard" :D I wish I had cuban cigars hidden in the little compartment.
McCall Pinz
OK, so if you copy this box, here are some tips- make it out of 1/2" ply to gain some interior room, leave about a 1/4" clear space to the seats so that you can still flip them up and down, and use the 4 big bolts in the bulkhead to hold the thing in place in case you tip over. The teeny little subwoofer is now in place and it helps with the sound, but isn't too "thumpy". Here are some pictures of the backside too, so you can see where the snorkel goes.
Spiffy! Can you post a picture of how you ran the snorkel through the bulkhead and into the intake?
I would like to see that as well. Thanks
McCall Pinz
I think the snorkel was posted before. Mine uses the factory 716 piece for the intake, then runs back and down through a hole in the bulkhead. The aircleaner is rotated so the intake points backwards and the flappy preheater is removed. Bernhard's is nicer actually- http://www.real4x4forums.com/PinzgauerB ... it=snorkel
I really like the idea of this amp board, so I think I am going to go this route for my truck. While checking out the website (parts-express) and the AMP board, I found this barrel plug...(it is rated up to 24v)
http://www.parts-express.com/pe/showdet ... TR=335-330
Parts-express confirmed that it will fit the AMP power source plug. Now my question is, do you guys see any advantage to it...rather than screwing the wires directly to the AMP board? I was just thinking it would be easier for removal etc....
Why are you contemplating removing it...to install in a secondary vehicle? I would think that once it is in you're done.
