In my quest to to get this 710m ready to go for the nice weather, I am going over things I read about here and on SDP. One of the "easy" projects I planned on tackling was the noise reduction technique. After removing the tranny cover plate from inside the bed to get a better look at the tranny mount, I noticed right away that the inner top bolt was loose. Unfortunately, the problem is that the welded-nut has spun loose
! I then got under the truck and found that the lower, inner bolt was missing! On closer inspection, it had been snapped off and left inside the welded nut
! What idiot does that???
Anyway, I went ahead with the rubber hose add-on, but now I am stuck as to what I should do about the broken weld-nut? Can I slip a nut in there and hope I can get a pair of pliers in their to hold it when I tighten it?
- gear06.jpg (7.75 KiB) Viewed 4378 times
The bottom bolt I will drill out an hope to salvage the nut.
