Hi-Lift 4XRAC Mounts
I have read a few posts on the hi-lift mount guys have used on the noses of their Pinz's, and I just wanted to confirm if this was the part? Obviously drilling is required....
Re: Hi-Lift 4XRAC Mounts
Wow, I just bought one of that very same mount kit yesterday. I plan to mount them on the placard plates on the nose of my "K". If it goes according to plan, no new holes will be required to be drilled into the body
'76 710K
'76 710K
Awesome Mike! Could you take some pics of your install?mm58 wrote:Wow, I just bought one of that very same mount kit yesterday. I plan to mount them on the placard plates on the nose of my "K". If it goes according to plan, no aftermarket holes will be required to be drilled.
I know ScottishPinz used the radio tube mount points on his 710K so no new holes drilled.
viewtopic.php?f=6&t=8069&start=15
I know you have a 710M so not really the same just passing it on
GenevaPinz mounted his inside his 710M
viewtopic.php?f=18&t=6897&hilit=Hilift
I plan on using the same mounts as the tube holders, but I read elsewhere....4X4Pinz.,,had to drill the holes for the centre bolts, versus the side holes.
Sent from my Mobile
Sent from my Mobile
I'd gladly post pics if I can figure out how. I'm taking VGA sized .jpg's an when I try to upload any to a post, I get an "invalid" result.
'76 710K
'76 710K
mike, send them to me and I will post them for you. I can resize them so you can post them also.
The mounts I used which required drilling were the ones in the photo. They were old school Hi Lift jack mounts. Have not seem them for sale in a while.berger wrote:I plan on using the same mounts as the tube holders, but I read elsewhere....4X4Pinz.,,had to drill the holes for the centre bolts, versus the side holes.
Sent from my Mobile
- hi lift mount 002 (Small).jpg (49.26 KiB) Viewed 7127 times
- hi lift mount 001 (Small).jpg (40.06 KiB) Viewed 7127 times
Pics of MM58's jack mounts
- IMG_20130522_190044 (Small).jpg (53.71 KiB) Viewed 7122 times
- IMG_20130522_185944 (Small).jpg (63.85 KiB) Viewed 7122 times
- IMG_20130522_185933 (Small).jpg (47.47 KiB) Viewed 7122 times
- audiocontr
I used nylon spacers, washers and a long bolt w wing nuts. Worked great. Used stock holes. All from Home Depot.
That's how I mounted mine. I used some 1/4-20 rivnuts on my 712.
1974 712M AKA the Banana
1987 718M Now Sold
1975 Volvo TGB1111 Now Sold
1963 404S Now Sold
I prefer this method.
- ed olson bumper.jpg (35.04 KiB) Viewed 7072 times
Are those your mounts?Andre wrote:I prefer this method.
I like that as it uses the tube mount bolts correct?
- ScottishPinz
Mine is attached to the existing arial tube mounts on the front, but it is only the bar of the jack, the rest is stored inside.
- IMG_6201.jpg (58.44 KiB) Viewed 7059 times
- IMG_9678.jpg (59.94 KiB) Viewed 7059 times
- IMG_4404.jpg (26.84 KiB) Viewed 7059 times
