Hi-Lift 4XRAC Mounts
I have read a few posts on the hi-lift mount guys have used on the noses of their Pinz's, and I just wanted to confirm if this was the part? Obviously drilling is required....
mm58
Re: Hi-Lift 4XRAC Mounts
Post by mm58 »
Wow, I just bought one of that very same mount kit yesterday. I plan to mount them on the placard plates on the nose of my "K". If it goes according to plan, no new holes will be required to be drilled into the body
'76 710K
mm58 wrote:Wow, I just bought one of that very same mount kit yesterday. I plan to mount them on the placard plates on the nose of my "K". If it goes according to plan, no aftermarket holes will be required to be drilled.
Awesome Mike! Could you take some pics of your install?
I know ScottishPinz used the radio tube mount points on his 710K so no new holes drilled.
viewtopic.php?f=6&t=8069&start=15
I know you have a 710M so not really the same just passing it on
GenevaPinz mounted his inside his 710M
viewtopic.php?f=18&t=6897&hilit=Hilift
I plan on using the same mounts as the tube holders, but I read elsewhere....4X4Pinz.,,had to drill the holes for the centre bolts, versus the side holes.
Sent from my Mobile
mm58
Post by mm58 »
I'd gladly post pics if I can figure out how. I'm taking VGA sized .jpg's an when I try to upload any to a post, I get an "invalid" result.
'76 710K
mike, send them to me and I will post them for you. I can resize them so you can post them also.
berger wrote:I plan on using the same mounts as the tube holders, but I read elsewhere....4X4Pinz.,,had to drill the holes for the centre bolts, versus the side holes.
Sent from my Mobile
The mounts I used which required drilling were the ones in the photo. They were old school Hi Lift jack mounts. Have not seem them for sale in a while.
hi lift mount 002 (Small).jpg (49.26 KiB) Viewed 7132 times
hi lift mount 001 (Small).jpg (40.06 KiB) Viewed 7132 times
Pics of MM58's jack mounts
IMG_20130522_190044 (Small).jpg (53.71 KiB) Viewed 7127 times
IMG_20130522_185944 (Small).jpg (63.85 KiB) Viewed 7127 times
IMG_20130522_185933 (Small).jpg (47.47 KiB) Viewed 7127 times
I used nylon spacers, washers and a long bolt w wing nuts. Worked great. Used stock holes. All from Home Depot.
Thanks guys!
mopar
Post by mopar »
That's how I mounted mine. I used some 1/4-20 rivnuts on my 712.
1974 712M AKA the Banana
1987 718M Now Sold
1975 Volvo TGB1111 Now Sold
1963 404S Now Sold
Andre
Post by Andre »
I prefer this method.
ed olson bumper.jpg (35.04 KiB) Viewed 7077 times
Andre wrote:I prefer this method.
Are those your mounts?
I like that as it uses the tube mount bolts correct?
ScottishPinz
Post by ScottishPinz »
Mine is attached to the existing arial tube mounts on the front, but it is only the bar of the jack, the rest is stored inside.
