Big white smoke , all RPMs.... Advice?
Re: Big white smoke , all RPMs.... Advice?
Sorry your first Pinz experience has been so brutal ($$). They're not all this way -
George Cameron
Yarnell, AZ
1979 Pinz 710M
Molon Labe
Yarnell, AZ
1979 Pinz 710M
Molon Labe
You may want to pull the cam and make sure the pressed in bore end plugs are not loose or missing.
It would result in lack of oil volume to the piston skirts.
Another thought as you mentioned the 2.7 kit -
You are probably correct that the pistons and cylinders were match fitted (as an individual piston/cylinder pair), but that doesn't prevent the mechanic from getting pistons and cylinders swapped around during ring fitting, con rod installation, etc. It would only take a couple of thousandths of an inch to give problems.
George Cameron
Yarnell, AZ
1979 Pinz 710M
Molon Labe
Yarnell, AZ
1979 Pinz 710M
Molon Labe
Jim,
I'm not getting the relationship between the cam button/plugs and the pistons. Can you expound a little?
'76 710K
Jim,
Found your write up. Excellent explanation, THANKS!
http://www.real4x4forums.com/PinzgauerB ... hp?p=28709
'76 710K
That's great info! Thanks guys for all your input; digging out Jim's write-up & the points Jim is making
I'll keep you posted on progress and discovery when I talk with the machine shop people!
