How difficult and expensive is it to paint your Pinz body?
Has anyone painted their Pinz body? Any info on difficulty and expense is appreciated.
Re: How difficult and expensive is it to paint your Pinz bod
That is pretty wide open question...
repaint same color, different color, just outside or also inside, tape off most removable items or remove most items, body on or body off, etc etc
Sticking with same color should cost less but it also all depends on the condition of the body and paint your starting with and what you expect your finish to look like when your done.
Sorry for the lack of an answer but hard to provide one with info provided.
I go a bit on the less expensive side as I am scratching up the sides with bushes much too often. I buy my paint at WalMart,... Camo, OD rattle cans for $3.49 each and I keep a few on hand for those awkward moments. I can paint the entire pinz, inside and out for about $25. Usually do it one a year at least.
I did read a post about a guy that spent upwards of $5000 to paint his pinz.
- DSC02744.JPG (120.34 KiB) Viewed 6499 times
I painted my 710K in my yard, cost me about $250 with sandpaper and being I had to buy a sprayer.
Turned out real nice, just can't seam to load pictures of it now??
Look up: Fresh coat of Paint on Pinz
It will show pics of it. However it was some work do, but cost was nothing really.
What if someone's wife tends to not like OD? If totally changing the color, perhaps to tan? Has anyone done that?
I would think in AZ tan would be the best. The OD gets really hot to the touch. I painted my Mog desert sand as I spent lots of time in the SoCal desert.
I leave the pinz OD because here in CO it really doesn't matter. WalMart also has camo paint in sand color.
I know people that have pinzies in all colors...red, blue, white, tan, OD, black...the list goes on. Pick one your wife likes, it will be good for you..
Walmart also carries tan camo Krylon spray cans. My truck has tan stripes. Scuff up the surface and go nuts. Works as well as their o.d. version.
OD and Tan keep it military. Other colors 'civilianize' it.
Mine will be white and flat black
Spray cans $3-10
Good auto paint $200-700
All depends what you want
Spray cans $3-10
Has anyone painted the inside, or is it mostly and outside color change for those that change the color? Seems like it would be a much more difficult job to paint the interior.
ExpeditionImports
Painting depends on whether you are going for the pavement pounding princess or all around fun offroad camping Pinzgauer. Changing color can be tricky. Stay away from bright colors on the inside of a vehicle. Weird things can happen with people in vehicles with bright interiors as far as motion sickness. Most vehicle interiors are pretty muted in color.
Painting Pinzgauers can be as expensive as you want. Except for our corporate clients we recommend keeping it simple. You are never going to get that money back. Deal with any rust issues if you have any in the front door just under the windows and some of the other locations. No matter how much you grind and sand media blasting is best and metal etching primer does not hurt. Inside we usually recommend bedliner but that is expensive. Recommend staying away from any thing more than satin for paint finish. The body metal of a Pinzgauer was never intended to be a gloss paint Class A surface more like Class B. Don't really recommend blasting the entire truck, expensive, time consuming and value wise not your best option.
If you are going at it heavy deal with any cracks that show up on the nose from the clutch and brake pedal brackets.
- IMG_0738.JPG (54.85 KiB) Viewed 6442 times
Vallejo, California
www.expedition-imports.com
Vallejo, California
I take a slightly different approach......Whilst I like the hard tracks, it doesn't necessarily mean that you have to damage your vehicle to get through.
Careful driving saves LOTS of damage (panel and paint)
So my recipe on the 712 (and the 718 I'm currently rebuilding) is:
Abrasive blast every surface, then epoxy coat it all and eventually two-pack undercoats and colour.
Two packs are hard and a straight colour, unlike a metallic with a clear coat, can be polished every now and again without fear of cutting through.
Mine has been on the road almost 20 years now and the paint is still shiny.......In August my niece is getting married and she wants to arrive at the church in the 712, so I'II put a bit of extra effort in and polish it up really well
1997, 718 6X6 Pinzgauer
SNIPExpeditionImports wrote:Painting depends on whether you are going for the pavement pounding princess or all around fun offroad camping Pinzgauer.
Andre and a painter are doing mine. They are scuffing the OD and then will be shooting with a commercial Martin Señor paint. Key for me was the salt spray rating, chemical resistance and abrasion rating. This paint will stand up to acid and brake fluid with no degradation.
Once body is painted it will come off and we will do underneath in the same paint but flat and then move on to undercarriage. Inside gets heat and noise reduction spray and then black bedliner (front and back).
My Pinz has officially been dubbed...
"PINZESS"
But it will not just be a pavement pounder
So, again - all depends on what you want and need in terms of cost to paint.
nicholastanguma
Sounds like some blood awesome body armor paint. What kind, exactly, and what clearcoat from Martin Senour have such high salt spray, chemical, and abrasion resistance ratings?
Few yrs back, I got a quote from a good shop in san Diego that was in the 8k range for paint and powder coating the 100 plus pieces that make up the non-body parts ( cage, bumpers, top ribs, seat frames, etc etc. Needless to say- it's still OD.
Jorgo
24 TIRES
'73 712M
'74 712M
'04 G500
'07 Range Rover
"Those who were seen dancing
were thought to be insane
By those who could not hear the music"
24 TIRES
'73 712M
'74 712M
'04 G500
'07 Range Rover
PRISM acrylic polyurethane single stage so no clear coatnicholastanguma wrote: Sounds like some blood awesome body armor paint. What kind, exactly, and what clearcoat from Martin Senour have such high salt spray, chemical, and abrasion resistance ratings?
It is part of their commercial product line Then one of there Hardeners - discussed with the paint tech in Dallas
