24V Horn
24V Horn
Haven't been able to find one so thought I would just ask.
Looking for a 24V horn...not a 12V air horn with a resistor...to replace the pinz horn. Really want something that can be heard over traffic noise. Not necessarily to be noticed two states away just a replacement for the little beep that reminds me of a VW from 1964.
Any suggestions/leads will be appreciated.
Re: 24V Horn
Like this?
http://mudflaps.com/i-14313350-hella-h3 ... ltone.html
or get it for only $15+ shipping here: http://www.summitracing.com/int/parts/h ... /overview/ if they actually have it!
63rover
Re: 24V Horn
Post by 63rover »
2 of your favorite 12 v horns in series is another way to go. Your local wrecker will be happy to make a good deal.
Re: 24V Horn
Just remember that most 12V horns ground through their mounting brackets, so you would have to electrically isolate the mounting for the "upper" horn, and connect this horn's mounting bracket to the "lower" horn's terminal. AND, this typically forces both horns to operate at the same frequency (tone), even if they are specified as different frequencies. So you would get more horn volume but not necessarily the common two tone sound.
GRCameron
Re: 24V Horn
Post by GRCameron »
Have you looked on ebay? "24V horn -air" is one search term that returns many options. The loud horns draw quite a bit of current. You might want to add a relay so that the horn button contacts don't weld themselves shut.
George Cameron
Yarnell, AZ
1979 Pinz 710M
Molon Labe
GenevaPinz
Re: 24V Horn
Post by GenevaPinz »
I have this one in low-tone. It is loud enough.
http://www.rallylights.com/hl8512-super ... 09-db.html
Jan
'72 Pinzgauer 710M
