Yes! You CAN easily get an open end wrench onto the nut on top of the body mount bolt. You access it from the space just under the bed and forward of the mount bracket.undysworld wrote:IIRC, you slide an open end wrench onto it from the front. Sorry, it's been a long time.
Hand Brake issue.
Twin Pinzies
Re: Hand Brake issue.
Twin Pinzies
Latest issue...
Ok so I got all of the bolts off of the tail cone and body mount quite easily but when I pulled the cone back to remove it from the fixed bolts studs, the housing contacts the body mount bracket, preventing it from being fully removed.
It seems that I'll have to jack up the entire body tub in order to get enough clearance to pull the cone off and access the hand brake mechanism!
Any thoughts?
Any thoughts?
That is why I posted those pictures of having to use a 'C' clamp to press the body back down. I could not remove the surround of the brake without lifting the body. I only did one side as it was enough to allow the surround to be removed. There may be another way to do this but I could not think of one, perhaps someone has a better idea...if so I do hope they speak up. I would like to know for future repairs.
- David Dunn
The rear outrigger bolts to the body need to be released (or loosen almost completely) so the body can be lifted off the backbone to let the tailcone be removed.
