Ponz timing help needed
What is the correct degrees for timing on a 73 pinz and rpms setting
- Hotzenplotz
Re: Ponz timing help needed
it depends ....
first
ensure that the distributor rotor "clicks back" to ensure the dynamic adjustment works
if not, disassemble and grease /fix
then
set the points to 0,4 mm
do a static setting using a test-lamp
once you got the tin humming, rotate the distributor until it "sounds right" ...
first
then
Albert
Albert
Do you have points or Pertronix ?
BTW this is covered in the operators manual (around page 150 iirc) if your truck is stock and on Scotts site if Pertronix has been installed.
Yes sorry it does have the petronix civilian upgrade
Time the pinz setting the ignition 3-5 degrees BTDC. 850 - 950 rpm.
https://support.expeditionimports.com/h ... ix-Install
https://support.expeditionimports.com/h ... ch-Support
Thanks guys for all the quick responses
