New Volvo c304 owner new engine swap/ camp rig project
Re: New Volvo c304 owner new engine swap/ camp rig project
After I got everything mounted and the frame was holding its new power plants on its own, It was time to check and make sure nothing interfered with the new power plant.
- 117765646_318817242507945_3345705843586360529_n.jpg (546.2 KiB) Viewed 11120 times
- 118199352_1244161312603844_7441719029173207965_n.jpg (652.7 KiB) Viewed 11120 times
- 91702727_3006116649446667_2618628881627742208_n.jpg (632.68 KiB) Viewed 11120 times
- 93315087_222101679065604_8948465065867083776_n.jpg (324.17 KiB) Viewed 11120 times
She sits in there nice and snug but still plenty of room to work on!
Next I decided to tackle the steering as I couldnt move her around the shop without getting steering functional.
I removed the clutch pedal and modified the brake pedal assembly to hold my steering drop box. I did this for two reasons. One was to make it clean and simple in the footwell so I didnt have many rotating parts that my feet could get in the way of... Also I wanted as much room as possible in the cab for my feet and to be comfortable. I used the power steering gearbox from a RHD postal jeep. I used a custom short steering column based on the chevrolete steering columns and I mounted it to the dash. And with a couple ujoints the 3 components were connected! I had to lengthen the drag link bar and build a custom pitman arm. I also removed the big round crossmember and added a rectangle tubing crossmember a little further back.
- 104400445_667322667157434_4866333231650772465_n.jpg (348.22 KiB) Viewed 11120 times
- 104846518_257937142131197_2578190973884500708_n.jpg (361.03 KiB) Viewed 11120 times
- 116430934_851874158929922_367145531614891748_n.jpg (401.77 KiB) Viewed 11120 times
- 117766769_327847051597090_2295078972948243816_n.jpg (42.48 KiB) Viewed 11120 times
- 118241117_344069126766626_6210365592069226697_n.jpg (551.48 KiB) Viewed 11120 times
More pics
- 104839328_270333674382588_973094103350369917_n.jpg (331.82 KiB) Viewed 11120 times
- 104434308_304052647655070_4123469071746202893_n.jpg (372.69 KiB) Viewed 11120 times
- 104683563_2689328684615072_6877885977725790200_n.jpg (337.99 KiB) Viewed 11120 times
- 108213494_748841012599605_6955326367097801901_n.jpg (335.59 KiB) Viewed 11120 times
I then decided how I would mount the cab so i could finish the last of the steering components and make sure it all functioned properly.
- 108811095_2987946267995342_1024153136454031298_n.jpg (207.58 KiB) Viewed 11120 times
- 117054857_1649457861877491_751932147237192160_n.jpg (188.55 KiB) Viewed 11120 times
- 117444686_3305445699513301_5707445418747480099_n.jpg (354.31 KiB) Viewed 11120 times
- 117371787_369455484446145_784994815678635345_n.jpg (308.2 KiB) Viewed 11120 times
I am now working on getting the intake made up to where it will fit. I have also decided to go with an air over hydraulic setup on my brakes. I will already have an onboard air system for air lockers and 3rd axle disconnect.
This is where we are today!
I have ordered a bunch of parts that should be showing up within the next 3 or 4 weeks and then I can make another update! I am designing the cooling system now and the fuel system is already designed and installed but I do need a new fuel tank or to cut mine open and clean it out.
- spe-8721-d-air-hydraulic-8.jpg (596.58 KiB) Viewed 11120 times
- 116122083_229742268122266_1458800125330981485_n.jpg (403.26 KiB) Viewed 11120 times
- 109548786_344957693570357_5278618232389239261_n.jpg (442.12 KiB) Viewed 11120 times
DISCLAIMER!
I know im not the best fabricator out there! (yet) But its mostly all meant to be functional and easy to fix. Its not a show truck it will be used!
I should invest in some extra tooling like a proper welder (not flux core) and maybe a mill instead of an angle grinder. The pieces that have mattered I make sure I use the right tooling. The other pieces I have been doing with what I have. Working out of my small 2 car garage as well. I know I can probably do a bit better job if I take more time but I also dont settle for something that will fall apart or not work down the road (or off road)
I have enjoyed working on this project so far. I am hoping to have it running and driving by the end of this year!
roobar_and_custard
Nice progress! Steering looks good - never seen the drop box you used before, certainly frees up foot space.
Sitting the body up on rubber mounts is something I also plan to do (once my Volvo makes it back onto the "to do" list) - what mounts did you go with?
What a great update! Keep the pictures coming in.
geckoadventure
Joeri wrote: Sat Jun 06, 2020 4:29 pm You cant even do a chassis extension here in Belgium.....they will take your rig of the streets and it will never pas MOT.![]()
YUp same here in Malaysia legally cannot even weld stuff to the chassis it's confinscATED on registration or ownership change inspection.
How's this c304 coming along? It sure looks like a fun project!
