Turn Signal Trouble Shooting
Buzz
Post by Buzz »
I just replaced the turn signal switch on the steering column because it would not return to center and I could get no flash on the right side. New switch clicks as it should but still no right side flash. Suggestions appreciated.
1977 712
Re: Turn Signal Trouble Shooting
The Swiss turn signal switch is way more complicated than need be :((
They are a PITA to debug.
But...check your connections back to the Emergency switch, should be two wires.
A Black/Purple and a Black/Green. These lines provide the "blinking" power to the
turn switch. Could just be a loose or poor connection.
Failing that a multi-meter is your best friend.
Buzz
Post by Buzz »
Thanks, I will check that. FWIW, the truck is Austrian. But, a loose connection makes sense.
1977 712
Oh! The Austrian turn signal switch is simpler.
Didn't know I had a copy of the Austrian version schematic, attached. It's simple !
On the Swiss version the front and rear turn signals are separated and essentially a dual circuit
for front and rear and two blink sources from the hazard switch.
The Austrian is one circuit for left and one circuit for right with a common blink source. So if you
are not blinking on the right side but are blinking on the left that isolates your problem down.
Either a bad connection to the right terminal on the directional switch or all your bulbs on the
bad side are dead or a corroded connections.
The stock blinker needs a load on it to blink e.g. the filaments of the light bulbs.
Buzz
Post by Buzz »
Perfect! Thanks for your time!
1977 712
rollingpinz
Post by rollingpinz »
I have a Swiss and had the same issue. The right turn wire coming out of the turn signal switch plugs into a 3-way junction and one of the wires slipped off because it was loose. (Large hands and tiny work space) You may have to trace the connections back a little further.
Best of luck.
