Hi All
Last week I removed my rear springs as the tops were looking a bit rusty.
Can anyone give me any advice as to the procedure for removing the front springs? I can see it will be similar method and I will have to disconnect the limiting strap and the shock absorber prior to removal but I can see I do not have access to remove the bottom support pin as I did on the rear. If I prop the front and lower the drive arm then will the spring come out easily of will I have to get some spring compressors?
Any advice will be appreciated.
Sam
Front Springs
lindenengineering
