Locker Indicator Switches
Can anyone tell me where I can find the location of each of the switches for the locker indicator lights? My 4WD indicator light won't stay on and I already cleaned up the light socket and put in a new bulb. Thought it might be the switch but not sure where it is.
Erik712m
Post by Erik712m »
It is inside the cover that the wire is coming out of the diff.
milesdzyn
Post by milesdzyn »
It's in front of the Hi/Low gear box on the drivers side of the main frame tube, you'll find the switch under the little cap. If you remove the switch for inspection be careful as some gear oil may leak out.
Miles
'73 Pinzgauer 712M
Thanks to you both. I'll take a look tomorrow.
Erik712m
Post by Erik712m »
Paul you shouldn't have to take the switch out to see if it is working just undo the cover disconnect the wires and take an ohms reading with the locker off and locker on. in four wheel drive you should get resistance. At least i think the last time i looked at it i thaught it was. i would not remove it unless it was bad it is a pain to put back on.
Thanks Erik. I'd like to avoid removing the switch. I'm hoping it's just a bad wire.
todds112
Post by todds112 »
Theres also a connector if you follow the wire. Mine was pretty loose and corroded. Cleaned that up and it works great.
To verify the circuit, ground the wire going to the locker switch, if the light illuminates remove the cover and go to the switch. If the light still does not work, go under the truck and stsrt tracing connectons. By the body to tube hydraulic hoses there is a 3 (4x4)or 4 (6x6)wire connector. These get corroded, unplug it and ground each wire one at a time to test the circuit from there.
Thanks Todd and Jim. I'll let you know what I find.
Turned out to be loose, dirty and corroded connectors. Cleaned and tightened and everything is happy again :D
Thanks to all
todds112
Post by todds112 »
I think I've fixed 95% of my Pinz's problems with that technique. :wink:
