Sacrilege? Lowered ride height?
E_Swift
Post by E_Swift »
Pondering a 710K, but it appears it won't fit through 80" garage door opening. Don't want the Pinz to have to sit out during rainy season.
Have thought about different set of wheels/tires for storage - too much work.
Have considered taking off wheels and bolting on heavy duty low profile frames - same issue, too much work.
Has anyone used air springs to be able to adjust ride height on a Pinz? Or is this impossible?
Due to oversize tires currently mounted, I would need to lose about 6" of height to clear the 80" opening.
eToothpaste
Post by eToothpaste »
There is a guy on these forums that fitted his 710 with air springs. You should find it in a search.
He is no longer active here, as I have tried a few times to contact him with no response. He lived in southwest Utah.
How about a bigger garage?
Matt
E_Swift
Re: Sacrilege? Lowered ride height?
Post by E_Swift »
Thanks, found it. Looks promising.
viewtopic.php?f=9&t=3959&hilit=air+spring&start=15
If you have an older garage entrance, you may have standard 2x2x16" headers with several 2x4's above and below. It all adds up.
This can all be replaced with a "Gluelam" which can be considerably less in thickness and stronger. Then get yourself a door with
more sections, I've found one that is only 4" below the ceiling. This gets you at least 8" more clearance. I have the same problem
and looked into this -- it's on my wish list for to be done's. Don't putz with the suspension or tires you won't like that.
P.S. Don't ask the town building planners :? They sting you on these changes $$$$$ and time -- didn't hear that from me :P
ron
GRCameron
Post by GRCameron »
You shouldn't need a permit to "repair" a garage door. :)
George Cameron
Yarnell, AZ
1979 Pinz 710M
Molon Labe
GRCameron wrote:You shouldn't need a permit to "repair" a garage door. :)
From my experience, that depends on the municipality. In Madison, WI, we once got popped for no building permit for replacing a toilet! Not putting in new rough plumbing, just bolting down a new crapper.
Here, replacing a door is much different than repairing a door. Still, I'd probably ask forgiveness instead of permission, and just do it, maybe on a weekend...
E_Swift
Post by E_Swift »
Thanks, guys. I am no stranger to renovations, but in this case I think the vehicle would need to give way. The garage is full on brick and masonry construction (Not just facade) and has a good 25yrs of seniority on any Pinz.
Anything I am missing as far as downsides of the air suspension, other than cost and the need to carry onboard air tank and a compressor?
Lower the garage floor somehow?
or...
GRCameron
Post by GRCameron »
Wow! Here in Arizona things are a little different - more freedom. That's why my wife and I moved here from Kalifornia.
George Cameron
Yarnell, AZ
1979 Pinz 710M
Molon Labe
Pinzgauer Pete
Post by Pinzgauer Pete »
cant you just deflate the tires when entering the garage????
710M
Pinzgauer Pete wrote:cant you just deflate the tires when entering the garage????
x2
Where is the like button :)
E_Swift
Post by E_Swift »
edzz wrote:or...
Edzz, what is going on there? Rubber donuts on the brake drums??
E_Swift
Post by E_Swift »
x2
Yeah, that was my first thought. Asked the current owner when I saw the car - said he had already tried that, at least down to 10psi. Showed me the scar on his garage opening. Assuming any lower there is a good risk of popping a bead out?
E_Swift wrote:
edzz wrote:or...
It is my understanding that they are waiting to drive on-board a train that has height limits. The "wheels"
are just big enough to protect the brakes.
