There is a significant difference between a Converter (DC/DC) and a charger.
There are DC/DC chargers e.g. REDARC and others. Here I am assuming by
converter you are referring to a device to drive a load DIRECTLY and can that
also charge a battery -- no.
The converters control loop senses the output and drives that output to a specific
Voltage -- providing the necessary current to maintain that voltage.
A charger has several different output profiles varying both current and voltage
depending upon the "State of Charge" of the Battery and is different for different
chemistries; these are "Stages" and most chemistry types initiate the charge cycle
with Constant Current e.g. 10A, this current will be maintained until a specific
voltage is reached at the Battery (different voltage for different chemistries).
Once that voltage is reached the mode of the charger changes to a constant driven
Voltage (and again different for different chemistries) and is held there until a specific
battery current is reached (a low value) then a 3'rd Stage is entered this may "Float"
or some more sophisticated chargers is a short stage before the final Float stage. For
LiFePO4 batteries Float is not a trickle charge as per Lead Acid.
So.....using a converter to charge a battery has several problems. First it's bad
for the internal cells of the battery, wont get the proper charging. When you connect
a converter to a battery it is a constant voltage source, essentially skipping Stage 1,
if the Battery is low and needs a lot of charging, the battery will essentially hog all it
can out of the charger causing it to go into current limit, which is bad for the charger
and not a controlled charge for the battery. If it survives that (doesn't blow a fuse) then
the terminal voltage eventually reached at the battery may not be the proper voltage
for that chemistry, and for a LiFePO4 (LFP) it really wants to go open circuit as the final
Stage -- no trickle charge but monitoring the output.
Gezzzz --- that was long winded
Not knowing what your load is, sounds like it's pretty beefy. For most auxiliary applications,
except for Antarctica, I'd suggest LFP batteries. They are EXPENSIVE, but will outlive Lead-Acid
or AGM, half the weight with the same A-Hr rating, and a key factor is the output voltage will
sag far less than Lead-acid (lower internal resistance), important for loads that are voltage
sensitive. At the same rating I find these LFP's to be a far better power source than Lead-Acid
by at least 2X. One potential negative is they do not work well at freezing temp.
Last year I had it with my 4 Yellow Tops in my 710K and switched them out for a Battleborn
100 A-hr battery, charging via a REDARC dual-input multi-state charger BCDC1225D. Sources
from either the Alternator or roof Solar. A huge reduction in weight, and enough freed up space
to toss in a ARB compressor.
- Power Box.jpeg (94.03 KiB) Viewed 10541 times
Just some initial feed-back, hope this helps.
