US Ford transit wheels fit the 712k!!!!!
Re: US Ford transit wheels fit the 712k!!!!!
I'd be interested in a set of Transit Wheel hub steps.
Andre
Post by Andre »
I had built a set that screw on to the flange threaded holes previously.
Andre, that sounds interesting, can you post a PIX of these steps.
Hugues
Post by Hugues »
Hugues wrote: Thu May 15, 2025 7:40 am finally, after thinking about it, i''ll go for this tire:
BFGoodrich ALL Terrain T/A KO2
235/85 R16 120/116S 10PR  RWL  3PMSF...
So, bought the Ford rims
Bought 5 tires as per above brand/dimensions
Bought a manual tire changer
Mounted the tires myself, first time I do this
Using Magnum+ beads for balancing
Tested the truck today, all is good
Hugues
From Switzerland
That looks pretty darn good !! And...235's look plenty wide and tall enough.
That's what I plan on moving to for my next set of tires.
compunerdy
Post by compunerdy »
Looks great!
Tim
1975 710K
Hugues
Post by Hugues »
compunerdy wrote: Fri May 30, 2025 10:20 am Looks great!
thanks guys,
now i already miss the hub steps i bought from you ://
there might be a way to re-use them on the Ford transit wheel, with a small modification
I describe my idea in this short video,
what do you guys think ?
https://youtu.be/xHUl3aG4lCY?si=_qnDQjPtRxdDKWQi
Hugues
From Switzerland
compunerdy
I do not see why it wouldn't work but if you want to wait a little bit, I will have my test set made specifically for these wheels done soon. Just waiting for a machine to free up.
Tim
1975 710K
I for one can wait.....not moving over to these Transit wheels for a bit.
Love to see PIX's when your done turning these puppies out :wink:
compunerdy
Some pics of the Transit wheel steps and center caps
Tim
1975 710K
Yikes !! That's some mighty nice work man. I also now see Hugues's prior fitup on the Pinz wheels
posted earlier on this thread viewtopic.php?p=93867#p93867
One thought/recommendation before you machine these up -- just for consideration. Please keep
the extension from the wheel surface no more than 3".
From my own experience with the Cold War Remarketing version, which are 4", they can take a beating on narrow rocky trails.
Beyond 3" seems to be when interference can happen. The T-Lo's version is 3" and that 1" seems to make significant
difference in exposure.
With Aluminum they won't be as forgiving.
cheers
compunerdy
They are 4" overall so they only stick out around 3" from the face of the wheel. Also, just made to the length requested by the customer and could be modified to whatever length desired.
Tim
1975 710K
compunerdy
Here are some pics of the steps I made for the Transit wheels. These are aftermarket wheels so not sure if they are the same as factory wheels.
Tim
1975 710K
Looks awesome. They should fit the OEM wheels.
I'd take a set -- a bit shorter though.
ron
