US Ford transit wheels fit the 712k!!!!!
Re: US Ford transit wheels fit the 712k!!!!!
I'd be interested in a set of Transit Wheel hub steps.
I had built a set that screw on to the flange threaded holes previously.
Andre, that sounds interesting, can you post a PIX of these steps.
So, bought the Ford rimsHugues wrote: Thu May 15, 2025 7:40 am finally, after thinking about it, i''ll go for this tire:
BFGoodrich ALL Terrain T/A KO2
235/85 R16 120/116S 10PR RWL 3PMSF...
Bought 5 tires as per above brand/dimensions
Bought a manual tire changer
Mounted the tires myself, first time I do this
Using Magnum+ beads for balancing
Tested the truck today, all is good
Hugues
From Switzerland
From Switzerland
That looks pretty darn good !! And...235's look plenty wide and tall enough.
That's what I plan on moving to for my next set of tires.
compunerdy
thanks guys,
now i already miss the hub steps i bought from you
there might be a way to re-use them on the Ford transit wheel, with a small modification
I describe my idea in this short video,
what do you guys think ?
https://youtu.be/xHUl3aG4lCY?si=_qnDQjPtRxdDKWQi
Hugues
From Switzerland
From Switzerland
compunerdy
I do not see why it wouldn't work but if you want to wait a little bit, I will have my test set made specifically for these wheels done soon. Just waiting for a machine to free up.
Tim
1975 710K
1975 710K
I for one can wait.....not moving over to these Transit wheels for a bit.
Love to see PIX's when your done turning these puppies out
compunerdy
Some pics of the Transit wheel steps and center caps
Tim
1975 710K
1975 710K
Yikes !! That's some mighty nice work man. I also now see Hugues's prior fitup on the Pinz wheels
posted earlier on this thread viewtopic.php?p=93867#p93867
One thought/recommendation before you machine these up -- just for consideration. Please keep
the extension from the wheel surface no more than 3".
From my own experience with the Cold War Remarketing version, which are 4", they can take a beating on narrow rocky trails.
Beyond 3" seems to be when interference can happen. The T-Lo's version is 3" and that 1" seems to make significant
difference in exposure.
With Aluminum they won't be as forgiving.
cheers
cheers
compunerdy
They are 4" overall so they only stick out around 3" from the face of the wheel. Also, just made to the length requested by the customer and could be modified to whatever length desired.
Tim
1975 710K
1975 710K
compunerdy
Here are some pics of the steps I made for the Transit wheels. These are aftermarket wheels so not sure if they are the same as factory wheels.
- Photos_sf22bOacdc.png (525.08 KiB) Viewed 4822 times
- Photos_QDEay4u5P9.png (539.71 KiB) Viewed 4822 times
- Photos_3TzalfJhM5.png (597.05 KiB) Viewed 4822 times
Tim
1975 710K
1975 710K
Looks awesome. They should fit the OEM wheels.
I'd take a set -- a bit shorter though.
ron
ron
I am moving over to Transist wheels on my 710K. The current wheels are custom 8" re-hooped stock cores.
They are just too wide for the tire width I run.
For a Hub Step, I decide to give it a go and fab one. Not as pretty as the one posted earlier but it's good enough.
I followed the basic design used by Cold War Remarketing (Going out of business).
The base which fits in the wheel cavity is 1/4" stock, jet cut into a circle from SendCutSend. Without a shim
the fit would be sloppy and rattle. To address that I used a 1/8" semi-stiff foam material on the backside to take
up the slop and provide a friction fit W/O interfering with the wheel mounting. Many people do something similar
with the standard hub step using a 1/16" neoprene. Pictures show Wheel and Step, also a side-by-side of the
standard step versus the Transit Step. I cut to a length of 3 1/4" to avoid interference with rocks etc.
